koni shocks and struts
Old Nov 22, 2003 | 08:21 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
i've been thinking about getting koni's for the front and rear, but first i wanted to get some back up from people who have them installed on their cars. so...who's got koni's and how are they?
Old Nov 22, 2003 | 08:29 PM
CanAmCam's Avatar
Car: Camaro
Transmission: stick
You like to drive fast? theyn Koni Yellows are the best out of the box strut you can buy for these cars. You want to impress a date? then stick with nothing more than a KYB.
Old Nov 22, 2003 | 08:41 PM
GTAman's Avatar
hey i'm no poser . i want something serious to make my GTA into a serious road car and i've always known KONI to be the best.
Old Nov 22, 2003 | 08:59 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I have Koni Yellows with an Eibach Prokit and a lot of other suspension mods on an 83TA.
I don't have another performance shock to compare with but the Konis work really well on my car. I ran it in an autox and also on a road course and I'm really pleased with the results.
When I was researching which shocks to get I read a lot of stuff where people said Koni Yellows were too harsh. I havn't found that to be the case for my preferences at least.
Old Nov 22, 2003 | 09:08 PM
GTAman's Avatar
when i last took my car to the shop to get the lower ball joint and strut replaced (both on right side) i found out that i have sensatracs (argh!!) in the front and *** knows what in the rear. i thought mcpherson shocks and struts came on the GTA? correct me if i'm wrong, but that can't be delivering the same results as my WS6 was ment to perform.
Old Nov 22, 2003 | 09:32 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
macpherson is the design of the front struts that's on the car - so the Koni fronts for example are still a macpherson style strut - the rears are just a standard shock design allowing of course for different manufacturer's ideas on which is better internal design for a given shock
some or maybe all of the irocs came with bilsteins but i'm not sure what your car would have had on it from the factory.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
