L98 power steering
Old Nov 24, 2003 | 08:51 PM
raefon's Avatar
Car: 1991 RS (being reworked), 2002 Ram-Air Trans Am
Engine: Will change soon
Transmission: Will change soon
L98 power steering
I recently purchased an L98 from a 91 Corvette. I didn't look into all of the details (apparently) and now have a power steering pump for a rack and pinion unit.
Does anyone know if it is possible to install the power steering pump from a Camaro L98 or L03 onto the Corvette L98 with a minimum of trouble?
Old Nov 24, 2003 | 09:09 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
the existing l03 or camaro l98 pump should bolt right up, but you may or may not need the complete driver's side serpentine bracket. i don't know if they are the same from camaro to corvette.
Old Nov 26, 2003 | 05:41 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i would use the f-body acessories, including the accessory brackets, and put them on the vette L98.
Old Nov 26, 2003 | 07:06 PM
raefon's Avatar
Are you saying that the brackets and accessories are a direct bolt up from a 305 TBI to the L98?
Old Nov 26, 2003 | 08:37 PM
Car: 1988 IROC-Z
YES. i've done this swap in the past week.
Old Nov 27, 2003 | 08:46 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
any small block serpentine brackets should be interchangeable.
also, guys who are looking for a/c delete pulleys.... try checking the wrecking yards for fullsize chevy pickups with 4.3 motors or the small blocks without a/c. two friends have 4.3 powered fullsize chevy trucks, and the a/c delete pulleys look identical to the small block one.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
