Best Brakes for GTA WS6 Crosslace rims
Old Dec 2, 2003 | 10:55 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
What are the BEST brakes I could build buy or fabricate to fit underneath my crosslace 16" rims.
I know the spoon 13" setup wont work.
The LS1 setup might work with spacers
the C4 setup works
wilwood sells their 4 piston setup
baer prolly sells a system.
WHICH IS THE BEST?
Old Dec 2, 2003 | 11:20 AM
SLP_GTA's Avatar
same delima
I really like, and going to keep my cross lace rims. I think the C4 set up is the best bang for the buck, but I'm unsure if the longer studs would prevent me for using the factory lugs and plastic caps, so thats kind of out.
I think Im going the 1LE route, I know it will fit the GTA wheels lugs and caps, and provide stopping power compariable to all, IMHO
Attached Thumbnails Best Brakes for GTA WS6 Crosslace rims-__hr_91-croped-1-.jpg
Old Dec 2, 2003 | 12:11 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have driven a firebird with the 1LE 4 disk setup and was not impressed.
I noticed somewhat beter feel but the braking power was not significantly improved over my disk drum setup (could barely lock up the tires).
Old Dec 2, 2003 | 08:17 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
<x>
Old Dec 2, 2003 | 09:30 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
yes all GTA's were ws6
Old Dec 7, 2003 | 04:22 PM
chrissy's Avatar
I've been faced with this dilemma as well......
As far as I'm concerned the stock brakes have to go. The thing I like about the C4 set-up is the availability and price of spare parts.
Though I believe the C4 brakes haven't yet been tried under a GTA wheel. There was a thread involving Eb Miller the other day about this.
https://www.thirdgen.org/techbb2/sho...hreadid=199076
Ed Miller C4 brake kit
Old Dec 7, 2003 | 04:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can always cut a quarter inch or so off the studs before you install them and get rid of the possible interference problem. Studs are fairly cheap...
Ed
Old Dec 7, 2003 | 08:36 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
This pic is of my rear wheel using the doorman/motormite studs. If these studs are used on the stock front rotors, then you may have an issue with the caps not fitting. The rear rotors/drums push the wheels out like spacers, so if you do the C4 upgrade then there shouldn't be a problem.
Motormite 98501
Dorman 610-323
Old Dec 8, 2003 | 03:58 PM
chrissy's Avatar
That's good news for everyone with these rims! Thanks for the pic slowTA.
"Motormite 98501
Dorman 610-323"
What does this mean? Is it part numbers for the studs?
Old Dec 8, 2003 | 04:02 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am still waiting to see if someone can fit the LS1's under these rims.
I think the LS1's would be the best brakes of all the current options IF they fit.
Old Dec 8, 2003 | 06:39 PM
slowTA's Avatar
Car: '88 Formula
Yeah, those are the part numbers. I found mine at a Napa dealer. I forget what brand they carry (they don't have both) so just give them the corresponding part number.
Old Dec 8, 2003 | 06:46 PM
ebmiller88's Avatar
Napa=Motormite. They're $1.80 each in Charlotte, but the number you listed isn't right. It's 6411581.
Ed
Old Dec 8, 2003 | 07:00 PM
slowTA's Avatar
Car: '88 Formula
Sorry to disagree with you Ed, but I checked the motormite website and both of my part numbers returned valid wheel studs. Your numbers were invalid.
http://www.motormitedormancatalog.com/start.wws
Old Dec 9, 2003 | 07:38 AM
ebmiller88's Avatar
You are right and we may be both right...the number I posted is the Napa crossreference number. The MM part number posted won't work at my local Napa in their system.
Ed
Old Dec 9, 2003 | 07:53 AM
slowTA's Avatar
Car: '88 Formula
I guess this is another case of 'internet' information being incorrect/misleading/wrong!
Old Dec 11, 2003 | 08:25 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Baer
I know for a fact that the Baer 12" system will fit inside the crosslace rims because that's what I'm currently running on my car. At least for now until my 409's get in sometime next week. They only have about an 1/8" clearance between the calipers and the rim, but they do fit.
Old Dec 12, 2003 | 06:47 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... 1LE with the right pad for the application it's being used for and they are just fine. 12" rotors front and rear.
Old Dec 12, 2003 | 06:50 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
... and since it's not a street car anymore, I don't need the plastic caps anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta90
Sep 15, 2015 04:00 PM
