getting rid of a torque arm
Old Dec 6, 2003 | 12:09 AM
xeroxed74's Avatar
ive been thinking about ways to get rid of my torque arm. does anyone know how hard itd be to switch over to a ladder bar or 4 link rear suspension. i plan on x bracing the chasis adding sub frame connectors and doing a rear cross member. this is a t-top car and im building the motor for it now and plan on having around 500 hp and about 550-575 ft. lbs of torque. modifying floor pans is no problem seeing how no one will be in the back seat anyways so it can just be ripped out.
Old Dec 6, 2003 | 06:27 AM
ede's Avatar
ede
it's simple if you want to eliminate the torque arm, just back half the car and switch to a 4 link or ladder bar suspension. 4 links as a rule don't preform as well on the street as a ladder bar does. i guess "how hard" depends on your abilities and tools and equipment you have at hand.
Old Dec 8, 2003 | 09:01 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
why would you want to eliminate your torque arm?
Old Dec 8, 2003 | 10:31 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
to end up with this:
the 2 red arrows are the lca's the yellow arrows show the front mounting points and the rear attachment of the lift bars on the axle, and the crossmember
this is the SSM lift bar setup
Old Dec 8, 2003 | 10:35 PM
Car: '91 Camaro RS
Heres the crossmember and lift bars out of the car.
the lift bars are welded to the axle tubes and locate the pinion angle...
much stronger than a torque arm, and it launches straight and smooth as can be......traction is excellent as well.
Car: '91 Camaro RS
one more pic.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
