Aluminum spare from '86 T/A fit over my '89 Formula rear brakes?
Old Dec 6, 2003 | 05:36 PM
formul8!!'s Avatar
Car: 2004 GTO
I have an aluminum spare out of an '86 Trans Am with the crosslace wheel option. .
Will it fit over the '89 WS6 disc brakes? I think I saw somewhere it will not work.
I got a flat one time and had my wife bring our '96 Z28 to where I was located because I didn't carry a spare. The spare from the '96 did not work and the inside lip was grinding on the caliper.
Old Dec 6, 2003 | 07:46 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
you should be able to use the spare from the 86 since its from a 3rd gen and not a 4th gen. remember on the 4th gens they had differnt backspacing on there wheels, thats why the one from the 96 was rubbing like that.
Old Dec 6, 2003 | 07:59 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
PBR rear brakes need a 15" spare.
Old Dec 6, 2003 | 11:55 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
my aluminum spare doesnt fit over my PBRs either, i havent tried my original steel one tho, my car originally had drums, now has disc.
Old Dec 7, 2003 | 02:30 PM
MdFormula350's Avatar
makes sense my 88 had disk brakes but they were not the pbr's which came around in 89. my aluminum spare worked fine with those.
Old Dec 7, 2003 | 03:52 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
I disagree - I tried to take a standard (read:not a spare) 15" wheel of an 87 camaro to put on my 91z w/PBR and if I had bolted it up, the face of the brake would have been grinding against the rim. PBR's have been a PITA for me...
Old Dec 7, 2003 | 08:01 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if u mesure the backspacing on the 87 wheel vs the 91 wheel, u will see clearly that the 87 wheel wont fit and thats why yours didnt work. the 91 z28's have a different back spacing on the front and rear wheels, so if u try and rotate them ull have problems. thats also why u see some people gettin i think its either 4 front rims or 4 rear rims so they can rotate the rims.
Old Dec 8, 2003 | 12:18 AM
Thirtybird's Avatar
That's some good logic, but it's actually hitting a ridge inside the rim.... 15 inchers without that ridge would clear, but the ones I have are all the same design - so I was SOL...
(trying some quick ASCII art....)
\_________   __   ___/
          \_/  \ /
Old Dec 8, 2003 | 10:14 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
People get 4 fronts.
I had 4 front GTA's on my 86.
I now have 4 front 16" Formula wheels on my 88.
Old Dec 8, 2003 | 11:13 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats it , i wasnt sure if it was the fronts or the rears that people got 4 of them so they can rotate the wheels.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
z28addict8490
Aug 7, 2015 08:48 PM
