Easy Brake swap question
Old Dec 10, 2003 | 07:40 PM
Da91Bird's Avatar
I have a disc brake rear end from an '87 Z that I want to install. I need to know if the calipers from a '90 model will fit the '87 Z?
As a side question, will the hard line that is clamped to the differential housing of the drum brake rear end also work on the disc brake rear end?
Thanks!
Old Dec 11, 2003 | 05:32 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
1. Yes, with the correct PBR backing plates. The two designs will not interchange.
2. Not without modding the ends of the tubing and probably lengthening them. It would be easier to buy new from Inline Tube or Classic Tube.
Ed
Old Dec 11, 2003 | 08:04 AM
Da91Bird's Avatar
Cool! Just to make sure I understand...the brackets will work fine, it's just the sheet metal backing plate that will not work?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
