Master Cylinder Question
Old Dec 10, 2003 | 10:19 PM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
I've got an 88 TA that came with a 10 bolt drum brake rear, and I am swapping in a 9 bolt from an 87 GTA. It has the crummy DM rear brakes, but they'll have to do until I can get the Baer setup. My question is, do I need to change the master cylinder/booster as well, or can I Use the old one. I tried the right master for a DM rear disc system, but I couldn't get any fluid out of the rear circuit, and I attributed this to the fact that the boosters are different. This is why I want to know if I can just use my old master, because I really don't want to swap boosters. Help!
Old Dec 11, 2003 | 06:01 AM
ede's Avatar
ede
i'd suspect the MC would work for either
Old Dec 11, 2003 | 10:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Master cylinders, while different, are interchangeable between disc and drum rears. GM had a TSB on this for customers who wanted to change their pedal feel.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
