looking for new "stock" coil springs ??
Old Dec 16, 2003 | 07:18 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
anyone know where I can buy new "stock" coils for my 91 ??
I have been looking online but cant find anywhere
Old Dec 16, 2003 | 10:21 PM
MdFormula350's Avatar
http://www.spohn.net/product.cfm?productid=1404
Old Dec 17, 2003 | 01:24 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Moog makes a good replacement set although I don't have them, lots of guys do. The numbers have been posted in here before.
Ed
Old Dec 17, 2003 | 10:58 PM
laiky's Avatar
moog pn 7665/7662
Old Dec 17, 2003 | 11:23 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Anyone have their website??? I am interested in a new factory set too
Will
Old Dec 17, 2003 | 11:48 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
these are the moog stock replacements. (IROC stock)
-brian
Old Dec 18, 2003 | 12:03 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I have the factory springs out of my 91 Z....
Old Dec 18, 2003 | 12:14 AM
norcalz28's Avatar
How many miles on them? I might be interested if they are low miles and not all messed up.
See the thing is my springs seem to be kinda worn, they dont hold the car like I think they should. I plan on adding some bilsteins as well, but I wanna put some stock springs on there. Now these Moog springs? Are these the standard rs/z28 springs or actual IROC springs. I know it says IROC style, but that term gets thrown around alot. IROCs sit .5" lower than the regular Z28, so I dont wanna turn around and make my iroc sit higher than it should, just stock....
Will
Old Dec 18, 2003 | 09:12 AM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
You shouldn't use used springs because they are over ten years old. They have lost their stiffness over the years and lots of weight loaded on them. It does depend on number of miles they have seen but even with zero miles they are as stiff as new any more
Old Dec 18, 2003 | 09:20 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Ive actualy used moog springs before in my 85 TA and they were cheap and worked well...I dont have any parts stores that will order them anymore ,so thanks for the link that will work out good!
parts stores near me dont even keep "cheap" shocks in stock for the Camaro
all I can say is parts stores near me are "SLACK"
Old Dec 18, 2003 | 09:32 AM
laiky's Avatar
the numbers i posted are for the IROC/later model z28. they are about 700lbs front and 110 rear but the rears actually seem much stiffer than 110 lbs. i had my doubts but they work great! only 105 bucks with tax.
Old Dec 18, 2003 | 01:03 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Are they 7665/7662 or 5665/5662?
Old Dec 18, 2003 | 01:54 PM
laiky's Avatar
thats a good question, i'll have to check. I'll get back to you tomorrow.
if you have time to search i have posted the correct numbers before.
Old Dec 22, 2003 | 06:07 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
How do these compare to stock '92 GTA WS6 springs?
I also need to replace original springs and might decide to stick with stock height.
Old Dec 22, 2003 | 06:17 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
5662/5665 are the correct numbers. I have two boxes with them in the garage right now. Best price I found was through Summit...even with the shipping (or "handling") charges thrown in.
Old Dec 22, 2003 | 06:55 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
summit sells stock type springs
Old Dec 22, 2003 | 07:46 PM
Car: 1989 GTA
Engine: 5.7L
Summit sells Moog suspension parts. 5662 & 5665 are Moog part numbers.
Old Dec 23, 2003 | 04:56 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
cool I'll check it out thanks
Old Feb 22, 2005 | 10:00 PM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
I found a 5664 (front) - for the IROC convertible.
Moog
Anyone tried these?
Old Feb 22, 2005 | 10:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Autozones duralast springs that are the same, and are also made by MOOG. Same part number as well.
Old Feb 23, 2005 | 06:19 PM
bubba353z's Avatar
Car: 07 Honda CR-V
I was just wondering how the extra spring rate affected the handling.
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
