SFC's fix this?
Old Dec 18, 2003 | 11:36 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
SFC's fix this?
The road I've taken to the shop the past 2 days is horrible. Uneven pavement where they tried to fix it everywhere. Whenever I go over it, I can hear my door like move up/down, the car rattles and I'm going crazy with the wheel to keep her in the turn.
Will SFC's do the trick? I'd like to wait until the 383 goes in but it's bad. Also, I'm getting the Wonderbar off of my GTA to go on the RS so that should help a little bit.
Old Dec 19, 2003 | 02:21 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
It will definitely help- but don't expect miracles. 90% of the creaks an groans went in my IROC when I installed my SSM sfc's. May as well just do the job now
Cheers,
Felix
Old Dec 19, 2003 | 07:16 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Subframe connectors are great to tighten up your chassis. You may also need to get a door hinge repair kit. Top down solutions sells them.
Old Dec 19, 2003 | 07:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yes it will help alot with the car flexing and wandering around the uneven road...
it will not eliminate the wandering entirely... if i had to say a number, id say it would reduce 85% of it... and 90% of the squeeks and twisting...
it holds the body still, but to fix that last little bit of wander, a STB and wonderbar will fix that (assuming you dont need new steering components)
Old Dec 19, 2003 | 01:18 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
STB = strut tower brace, right?
Old Dec 19, 2003 | 01:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yes.
Old Dec 19, 2003 | 02:40 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Ok guys, I just ordered some Jegster bolt-in frame ties. I've read good things and they're a good price. I'm going to weld them next year sometime when I can afford it. I'll let ya'll know how it goes.
-Corey
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Jlanz55
Sep 29, 2015 08:55 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
