Wheel studs
Old Dec 24, 2003 | 02:37 PM
colonboy14's Avatar
Car: Trans Am
Wheel studs
Has anybody sucessfully pressed the .509" knurl ARP studs into stock 10 bolt axles? Or should I go with the .486" ones?
Old Jan 1, 2004 | 04:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Still need an answer?
I haven't but I don't see why not...just drill the stud holes out to .500" and press the ARPs in. If you don't want to drill, use the Dorman studs and you'll be all set.
Ed
Old Jan 1, 2004 | 05:57 PM
Billyboy's Avatar
Re: Wheel studs
Yes I have them front and rear. The .509 are the ones you want. Just pull them through with lugnuts directly against the axle flange- I did not use a lugnut more than twice because it puts alot of pressure on the threads and can risk stripping the new studs. When done, use all new lugnuts to mount wheels- throw away any used to pull the studs into the axles or rotors.
I used ARP 12mmx1.5mmx 2 1/2" long-.509 knurl from Summit Racing. No drilling required.
Note: check the Wilwood rear disc post, you'll see pictures of the ARP studs there- https://www.thirdgen.org/techbb2/sho...hreadid=216339
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
