Sticking caliper slide bolts
1989 IROC. Has anybody found a decent, LONG LASTING, lube for the caliper slide bolts?
I've used the little packs of brake grease from AutoZone, motor oil, wheel bearing grease, rear axle lube....whatever I use, it dries up and gets sticky. I know when my caliper slide bolts are stuck is when the car pulls to one side or the other when braking.
For the time being, I'm using WD-40 on the slide bolts. It only lasts about a week but doesn't turn into cement like the other stuff. It sucks, though, having to spray the bolts so often just so the brakes will stop without pulling. Any ideas?
New2Chevy
Sep 28, 2015 12:35 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
