17" wheels, largest tire and back spacing?
Old Dec 27, 2003 | 10:37 PM
RecaroTA82's Avatar
Car: 1982 TRANS AM RECARO
Transmission: TH350
im curious as to what size 17 i should buy, ive seen a few cars with 17x9.5 all the way around and a few with 17x9.5 in the rear and smaller 17x8 up front . i want to run the largest wheel and tire package i can without having the wheels stick really far out,
Old Dec 27, 2003 | 10:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: 17" wheels, largest tire and back spacing?
since thats a matter of opinion, its up for debate... heh.
for the front, its generally agreed by everyone that 9.5 is the limit...
for the rear, you can goto 11" with a lil "modding" to the inner fender and trimming/bending the lip edge.
but of course, some people dont want to tap the inner fender with a hammer and roll the lip.. for the most part they have to stay between 10-10.5... keep in mind the panhard rod and a BUNCH of lil parts declare where the rear end is from side to side.. and on a production car, it varies.
so what works for someone just bearly may not for someone else.
keeping that in mind... measure your car yourself, and if you want WIDE rear rubber, a adjustible panhard bar is a good idea.
Old Dec 28, 2003 | 08:22 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can put 17 x 9.5 with 5.25" backspacing all the way around with 275/40-17 tires.
Old Dec 28, 2003 | 12:46 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
my race wheels are 16x10.5" CCW's... with 5.5" backspacing... 1/2" spacer in front...
they don't stick out at all
i've seen people autocross with 17x11 wheels with 315/35 tires... they fit with the correct backspacing... but they will stick out about a half inch
if you're going to go that wide(10.5 or 11).. you'll need an aftermarket panhard rod.. preferably one with rod-ends(no, it won't cause road noise)
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
