Locked brakes
Old Dec 30, 2003 | 02:50 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
Locked brakes
Okay, i have an iroc that sat for a loooong time and now the brakes are seized, the car will move, and once you get it going, it's driveable, but when starting to move its quite obvious the brakes are stuck in place, i was just wondering what the best way would be to loosen them up... ty
Old Dec 30, 2003 | 02:51 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
4 wheel disc btw
Old Dec 30, 2003 | 02:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the BEST way?
new calipers are about $12 each... for the fronts atleast, i donno the rears... if its too $$ for the rears, jsut rebuild them..
get new brake hoses.. the rubber flex hose...
turn or replace the rotors
new pads or if the old ones are still good, rough them up with some sandpaper on a flat board...
inspect and repack the wheelbearings (replace if you can)
bleed everything until its clean and clear with new fluid.
that would be the best way.
Old Dec 31, 2003 | 03:22 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
I had the same problem with my friends 74 nova. Damn thing wouldnt move at all. We hit it with some PB Blaster (kinda like WD-40 on steroids) and it loosened right up. Now im not sure thats very good for your car, personally id get in there and replace everything. Its just a quick fix...
And where are you finding calipers for $12??? Even the boneyards around here want like $25
Old Dec 31, 2003 | 04:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
reman calipers from the local parts store... and thats suppost to be 21.... misstype.
$12 will get you the rebuild kits.... no prob though...
athough i usually just get the caliper.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
