Proportioning valve problem
Old Jan 4, 2004 | 09:19 AM
stupid4901's Avatar
I'm in the middle of installing a 4th gen rear in my car and started to put in the wilwood valve. The only problem is that my car has metric brake lines and the FAQ is for standard. Will standard nuts fit on a metric line without leaking?
Old Jan 4, 2004 | 10:42 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the lines are the same, just the nuts and possibly the type of flare(double or bubble) is different
Old Jan 4, 2004 | 01:23 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
i know this is OT and will make me look like a retard but i havent had to do any brake work on my car yet. but what is a dubble and bubble flare?
Old Jan 4, 2004 | 06:34 PM
stupid4901's Avatar
The lines are defiinately metric i measured them and they aren't standard. Does anypne have an answer to my question?
Old Jan 5, 2004 | 03:51 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
The WilWood valve uses adapters that go from 1\8" pipe thread to SAE inverted flare ( 5\16" inverted flare I believe ...but don't quote me )
You can get adapters ( From a good Automotive jobber ) that go from 1\8" pipe to Metric flare. No big deal. You can get these in a Metric thread with double inverted flare style or the ISO bubble style depending on what you require. May take a bit of searching , but they are available. Check out Import shops that work on Japanese Race cars if your Automotive jobber is no good.
If you have a double flaring tool and you know how to use it properly, then you can put a Standard flare nut on a Metric line.
I've done this on Datsun Race cars many a time. Not a biggy...just make sure that the Metric lines and SAE fitting used are fairly close to the same inside and outside diameter. A " slight " difference is size is acceptable....just make sure that the flare is properly formed and that the nut is sufficiently secured.
Edit: Nuts...I didn't notice all the other threads that " stupid4901" had started. Hint...stick to the same thread. Add a post with the word " bump" if you don't get an answer right away. Umpteen posts on the same subject just makes things confusing.
Old Jan 5, 2004 | 08:10 PM
stupid4901's Avatar
Thanka chickenman thats exactly the answer i was looking for. Sorry bout all the posts just got kinda anxious.
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
