cant get rear calipers aligned with mounting holes
Old Jan 15, 2004 | 12:01 AM
thechristopherh's Avatar
took my rear calipers off, put the new pads on. and i cant get the caliper back on. there the piston is all the way retracted and the pads will slide over the rotor, however i cant get the caliper over the mounting holes because there is some washers or something stuck there that doesnt allow the caliper to slide back over the holes with new pads.
i have an 84 z28
Old Jan 17, 2004 | 02:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are these "washers" on the calipers? I wonder if they're the caliper "slides", and if they've shifted in their rubber bushings.
Old Jan 17, 2004 | 09:32 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Yes, Tom is correct. The "washers" are actually bushings that should move freely in the caliper holes. pull them fellers out, clean 'em, and lube 'em up good, stick 'em back in, and down the road ya go.......
Have fun.
Old Jan 17, 2004 | 03:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool, glad to see I guessed right!! If you want to buy a new kit, I bought a "rear caliper hardware kit", which came with new bushings and slides. The ones on my junkyard treasure were pretty rusted up. Kit was only $6, from Bendix, part # H5611- great buy! The local "real" auto parts store (not a pep boys or autozone), or a place like expressautoparts.com , will be able to order it for you.
What's not a great buy are the caliper mounting bolts (if yours are rusted, they should be replaced, unless you can lube 'em like ploegi said).. they're about $15/each- yep, each.
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
