Tubular K-Member
crazy both will add provisions for auto-x if asked for...to bad your across the way as i bet they would give you a discount for trial since you do what you do. that would set the record straight then wouldn't it.
Yeah it would. If it can handle drifting, guarantee it will be strong enough for daily street driving, auto-x, and roadracing. I'm looking for more ways to drop weight off the front and achieve the 50/50 distribution, so I might look into this further. When I have cash in hand I'll give these guys a call.
they are pretty reasonable...they knocked quite a bit off just by having their name published in an article with the car. i would assume some racing publicity would really help them nicely.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yeah you are correct. Grip cars experience way more stress than drift cars since we have no traction when we drift. Guess my statement was a little flamboyant there hehehe, sorry about that. I actually plan to participate in some wheel to wheel roadracing when I get the car done, though I wasn't thinking about that when I made my earlier post. I'm really wondering how it would hold up if I tapped the wall (same for CM A-arms).
Car: 1990 Camaro RS
i would really like to see this peice that is so talked about as teh 'auto-x' version. i have really thought about getitng one, and then modifing to fit my needs, but there are SO many other things that i can do to shed pounds first, i am not about to compromise the rigidity that i have built into my car right now, in the name of 30lbs of weight.
Car: 92 Z28
Engine: Boosted LSX
The way I look at it is. Most of us who have em dont Daily drive our cars. and if the Tubular members are made for Drag racing and can handle wheels up launches and landings They will handle a few weekend potholes and bad roads when weekend driven.
We are all careful to miss Huge potholes that are noticable anyways. Ya you hit em still but **** happens. I think the Tubular member was one of the cheaper priced parts for my car. If it cracks I'll get another one.
Car: 1990 Camaro RS
It isn't hitting a pot-hole that i am most concerned with, it is flexing it while going around PIR on sticky race tires, at over 1g lateraly.
Not to start a poo tossing fight but if the factory K-member was known to flex so bad that steering box braces and strut tower braces became beneficial. Wouldn't the single tube of an aftermarket K-member flex even more? Just asking. :lala:
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no.. the steering box braces brace the front "frame rail" box section from flexing under cornering loads..... because frankly, they're stamped steel sheet.
strut tower braces brace the top of the towers because thoes are also just thin steel sheet.....
notice you only have to brace the top, and in front where the K member isnt....
the Kmember is a heavily overbuilt thickmetal piece.. it doesnt flex... it'll bend if you smack a curb at high speed or somthing, but it doesnt flex.
Originally posted by SLP IROC-Z
how much did the power rack & pinion setup cost you? and was it more expensive to get the beefd up road racing K member made?
Sorry it took so long to get back on this forum.
The total was $1,389. From PRO FAB
That was for the C/M K Member, C/M A Arms, Bump steer kit, Coil over spring Kit, Cobra Power Rack & Pinnion conversion, and converted steering shaft. No extra cost for the stronger Road race version.
We just installed it yesterday and WOW I am very impressed!
In the high stress areas where the pieces weld together on the K member, there are gussets welded in also to make it stronger. On the A Arms there is extra cross bracing also.
Vern told me that with everything I have done, I will save 175 Pounds off of the front of the car. I like the fact that there is SO much more room to work around the engine.
I will post before and after pictures soon.
Oh it's better than nice! I love it!!!
It has a cool factor that is as good or better than anything else I've ever done on the car. It's too bad it is going to be covered up by an engine and will be hard to see...
Jerry
P.S. I have the C/M K-member, C/M A-arms and a coil over kit on my car.
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I'm with Jerry, I think they exaggerated a bit on the weight reduction. It will lighten things alot though!
Did you happen to take a pic of the k-member? I'm sure many other people besides myself would like to see what differences it has versus their regular one.
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
If the road race version is really a solid piece, and sheds some pounds, and looks good too, sign me up. Waiting for some pics of the RR verision showing extra bracing,etc.
ABSOLUTELY! Much more room for headers and spark plug changes. Especially if using a different motor like an LS1 or even a big block.
the whole reason i put one on my car was for room......so much more easier to work on the car. it's great they have the ability to add extra bracing for those who think the need it too! i love mine.
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Kandied, I know you have a ton of pics, want to throw one up of how much header room you have??
Or link us to a site maybe?
Car: 1983 Z28 being rebuilt
Engine: 383 Stroker 430 base hp
Transmission: Automatic
Sweet was just going to ask where i can get some tubular A arm but i guess i can order the whole front end now.
OK here are some of the installed pics of the PROFAB Crome molly K member, A arms, Coil overs, Power rack & pinnion, & bumpsteer kit.
in one of the pics you can see the gussets around the high stress points, and the extra bracing in the A arm.
Sorry the lighting wasn't better....
Car: 91 Camaro Vert
MrDude_1@excite.com
Yep, I took some with my Regular camera that has a flash. They will be good ones. I will get them developed and put on a Digital format this weekend. I haven't forgot, Just been busy.
Car: 91 Camaro Vert
he just stuffed my inbox full of these pics...
im posting them full size so you can see the detail.... (dialuppers, im sorry.
edited out overside pics
i cleaned out my inbox, so if he sends more, i'll post more.
EDIT: ALL PICS ARE HERE:
http://josh.swoca.net/board/mrdude/Kmember/
)edited out overside pics
Car: 91 Camaro Vert
heres all of the pics he sent me... tubular K member installed pics
i even took 5mins out of my day to thumbnail them..... all are fullsize when you click the thumbnail for easy viewing of details....
check em out.
check em out.
It looks really close. I am using Hooker Super comps. I've done allot of looking at it and holding the headers up to where I think they will sit. I think it will clear without dinging the header tube.
One thing to note is that the steering shaft turns and goes right through where the stock K member spring perches used to be. So the headers "should" clear.
The engine will be going back in within a day or two, I'll let you know how it goes.
BTW: Even though the new steering shaft angles pretty sharply it is very smooth when turning the wheels. Maybe because it is using true U joints. So far so good.
Car: 91 Camaro Vert
That steering intermediate shaft looks as though is is at a severe angle and would cause header problems.
if its like he says and clears the headers, then i think its fine... a 2nd U joint is a solution to the angle, but i think its not needed and would just add another place for slop to add into the steering.
Car: 91 Camaro Vert
thanks Boxeat2469... you broke my willpower.
ever since your post ive been thinking about getting one.... and how nows the time since im swapping motors....
at 4:30pm, i finally broke down and ordered one.
mild steel tubular K member... with spring perches... $250 + roughly $30 shipping.
No problem MrDude.
And if you really want to finish it off, they have the tubular A-arms with spring perches listed for $275. They're letting those go for $200 a set. Mine should be arriving today or tomorrow.
Car: 87 GTA
Engine: 355 Chevy
the steering shaft clears with minimal header rub on mine..I had to ding my header tube for clearance. Of course I bought my whole kit from P/A about a year and a half ago, so your new steering shaft from pro-fab should clear fine.
Twisted Wedge,
Is your steering shaft the same as mine, or did they change something?
What headers are you running?
Also, Since I have the Polly Motor mounts that raise the motor up Do you think it will help or hurt?
Thanks for your help...
