How many G's on the skidpad can I expect from these mods?
Old Jan 26, 2004 | 12:30 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Aftermarket:
Wonderbar
Swaybars 1 1/4, 7/8
all poly bushings on the front a arms and everything
hotchkis sport springs
new stock L98 shocks and struts
strut tower brace
panhard rod
Lower control arms
torque arm stock with poly bushing
16x8 Iroc Rims with goodyear gsc tires
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you left out the most important part.
what tires?
Old Jan 26, 2004 | 05:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Most bone stock 3rd gens can pull between .80 and .84. Although a recent magazine showed this to be a lot lower with a bunch of mods. I think that had track surface problems due to the similarly low numbers they achived for a SVT 03. Anyway, I have read numerous articles over the years that say .84 is about the norm. I would say you are still right around there to around .87 or so. Once you get subframes, and better tires your nubers could get as high as 1g. At that point you are at the limitation of street tires and can't get any higher.
Old Jan 26, 2004 | 10:23 PM
87350IROC's Avatar
Car: 87' IROC
I think you are underestimating the thirdgen. I have seen mag test results as high as .92G for later model cars.
Old Jan 26, 2004 | 10:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea I have to but I was making an average. I have seen some as high as .92 and others with the same mods around .85 to .88. It really depends on track conditions, and tire compound. But they are no slouch and you will deffinately have a hard time staying in the middle of your seat.
ZZ3Astro
Aug 13, 2019 12:57 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
hartsmike
Oct 2, 2015 07:11 AM
