Cutting Slotted Rotors
Old Feb 6, 2004 | 10:53 PM
Iceman0502's Avatar
I have slotted rotors on the front of my car. I was wondering if I was able to cut them the same way that I would cut normal rotors, even though they have slots in them. Please let me know becuase this will help me out greatly.
Nick
Old Feb 7, 2004 | 05:35 PM
Iceman0502's Avatar
Can anyone help
Old Feb 7, 2004 | 05:37 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I dont' see why you couldn't machine them, as the blade stays at the one setting. But I am not 100% sure either mind you.
Old Feb 7, 2004 | 05:59 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you mean cutting the slots all the way through? if so, you can do it, but you are more apt to warp your rotors if they are staock size. also, the slots are more than enough to reomove the gas that forms between the pad and the rotor, and also clean the pad no diff than the through sloted rotors.
also, you can have them turned if need be, but only with the accurcut time laith , because conventional laiths drag the blade there for draging the metal off, which if gaps are present, will cause the laith blade to chatter giving an iregular grind.
the accurcut laith blade actually cuts rather than drags, so the surface having gaps does not affect it as much, and also gives a cleaner and smoother surface. most gm dealers have the accurcut type laith.
thanks
anthony
Old Feb 8, 2004 | 01:00 PM
Iceman0502's Avatar
So the answer is that I can take them to my mechanic and have them cut. Thank you for your time guys.
blackandblue02
Sep 10, 2015 08:19 PM
84 TA NV
Sep 6, 2015 08:02 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
