Chrome Moly vs. Steel Torque arm
Old Feb 11, 2004 | 01:34 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Is it worth the $125 for the chrome moly torque arm over the mild steel?
Old Feb 11, 2004 | 01:43 PM
nolanr0413's Avatar
Car: Trans am
all the suspension pieces i have are chrome moly, i got them cause they are the best and i only want the best , i plan on keeping the car forever so i want to do it right the first time. its def lighter .
Old Feb 11, 2004 | 02:38 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Actually, I just e-mailed Steve Spohn about this same very thing and told him my car was running low 11's and he said the mild steel would be more then enough. So you do not have to go with the 4130 Chrome Molly that is offered.
Old Feb 11, 2004 | 03:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
way way overkill.
Old Feb 11, 2004 | 03:42 PM
ede's Avatar
ede
also moly is hard to weld if you ever need to change it or make a repair
Old Feb 11, 2004 | 03:57 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
The advantage of chromoly is that its alot stronger then steel. So what most companies do is that they can make the tubing thinner so that its still stronger then the steel version. Yet at the same time lighter then the steel version. If weight isnt really a factor for you then its not really needed. For me though I like shaving all the weight off the car that I can. So all of my suspension peices are Chromoly.
Old Feb 12, 2004 | 12:48 AM
Thanks for the info guys
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
