Front Tire Wear, Gimme an opinion
Old Feb 15, 2004 | 01:06 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Okay my front tires are wearing on the outside edge of the tread. From reading online and the Chiltons Manual, I have concluded it's probably my toe in setting. I also noticed when I make u-turns I get some front wheel hop if I turn the steering wheel to lock. I am planning on swapping some ball joints and whatever else looks bad, as I have all that on my part car, and I know it is realitively new. Just worried about when I do the swap, will I be able to do alignment, or drive it somewhere that can do alignment. I may also replace the strut Mounts as the ones in my part car may be in better shape also.
I have never done alignment before, but I was wondering how easily it could be done. Is it something I could do at home easily? What tools do I absolutely need? How much will these tools cost?
Thanks for the help, as this is my first real look into suspension and steering.
Old Feb 15, 2004 | 01:37 PM
bes217's Avatar
If it were me I would take my car to a shop that does alignments. I trust their work more than I would trust my own alignment work. Also they have all of the tools to do the job right the first time. Some people on here will tell you that it is not that hard though so whatever.
Old Feb 15, 2004 | 02:27 PM
laiky's Avatar
likely your camber is off. what year car is it? later cars have slightly different strut mounts that allow a little more caster. This sems to be a common problem with 3rd gens and the only solution i know of is to modify the mounts to allow more negative camber or get the Spohn/alloy mounts
colton_carlson
Mar 8, 2019 12:21 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
