rear end help please
Old Feb 25, 2004 | 11:07 PM
1987ws6tpi's Avatar
i was wondering if ther is any otehr maybe cheaper way to fix the spot were the sping sits on the rear end mine is rotting and dont want the spring ro fall out . thanx
Old Feb 26, 2004 | 04:52 AM
ede's Avatar
ede
cheaper than what way?
Old Feb 26, 2004 | 06:22 AM
1987ws6tpi's Avatar
well i did not know how much a rear end would be. or if i could just get the mouts and weld them
Old Feb 26, 2004 | 07:06 AM
conlinj's Avatar
you can probably get a v6 rear pretty cheap then add a posi later
Old Feb 26, 2004 | 08:05 AM
ede's Avatar
ede
should be able to buy a rear for 100 dollars. i bought a disk 10 bolt post for 175 few years ago.
Old Feb 26, 2004 | 10:25 AM
nolanr0413's Avatar
Car: Trans am
1987ws6tpi, can you weld, im sure you could find a rear end that is junk at the bone yard and then cut the spring perch off that one and put it on your car .
Old Feb 26, 2004 | 12:23 PM
1987ws6tpi's Avatar
thank man i will try that
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
