Eibach drag springs
Old Feb 27, 2004 | 04:05 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
Eibach drag springs
Anyone know where to buy them? I couldn't find any listed for third gens on their site...
Also, do you think it would affect anything by having a 4th gen rear?
Old Feb 27, 2004 | 04:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Eibach drag springs
I am pretty sure you can find them on summit or jegs. You will be fine with your 4th gen rear and they practically use the same stuff back there.
Old Feb 28, 2004 | 01:21 PM
MdFormula350's Avatar
i might have my set for sale, i didnt like the way it raised the rear up, and the spring compressor i used for the front ones wouldnt compress enough and i never did get the front ones on.
http://www.genxmuscle.com/store/EI9306-140
i am now using my eibach prokit on all fours and am using the airbag that comes with the drag kit.
email me if interested, like i said u will have to go out and buy the air bag separate but i do have all four springs for sale since i dont think i will be using them.
Old Feb 28, 2004 | 06:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hit me up with how much you want for them and i'll let you know if i'm game or not.
Old Feb 29, 2004 | 12:23 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
What does that extra airbag do?
Old Feb 29, 2004 | 06:28 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The air bag preloads the one side.For anyone that wants to know the Eibach Drag spring rates they are front both sides/337-514lbs.__ rear driver side/80lbs.__ rear pass side/80-217lbs.If you look around you could piece together a set of springs close to the drag kit for less money.I have a set of tall G-body springs (346lbs.) for the front and stock 4th-gen(114lbs.)for the rear.I didnt install them yet but they should give the car alot more weight transfer than the hard ws6 springs in there now.
92projectcamaro
Dec 8, 2015 12:25 AM
Antips16
Oct 30, 2015 06:42 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
