Were 1LE rear discs drilled?
Old Mar 8, 2004 | 11:52 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
were 1LE rear discs originally cross drilled??
Old Mar 9, 2004 | 12:05 AM
MdFormula350's Avatar
i dont think so. the rear disk were the same as the 89+ pbr disk brakes i thought.
https://www.thirdgen.org/techbb2/sho...=1le+rear+disk
Old Mar 9, 2004 | 12:36 AM
Car: 1989 RS Camaro
Well then mine must have been used for racing, b/c it has drilled rotors
Attached Thumbnails Were 1LE rear discs drilled?-my-1le-rear-disc
Old Mar 9, 2004 | 12:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
They weren't drilled. I don't know of any stock drilled rotors, except maybe ferrari's or something. Someone either had the stock rotors cross drilled, or theyre aftermarket rotors. Alot of people will say to stay away from cross drilled rotors though, because it makes it easier to crack them. Slotted rotors are usually reccomended instead. However, drilled rotors look cooler
Old Mar 12, 2004 | 12:07 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Only the poor quality drilled rotors will crack, and that because they didnt countersink the holes. And no, I have a 1LE car and they are not drilled, just slightly larger.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
gta90
Sep 15, 2015 04:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
