rear sway bar end links ?
Old Mar 11, 2004 | 11:15 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
i need to replace the bushings on the endlinks of my rear sway bar. i have 2 questions: 1) do i need to jack up the rear of the car even though i can slide under the car perfectly without it being jacked up and put on jack stands? and 2) JEGS sells the whole end link, bushings and all, but there are a couple sizes listed. does anyone know the length of the OEM spacer sleeve on the rear end links for a GTA? if anyone knows the measurement on the front ones that''d be great too.
-GTAman
Old Mar 12, 2004 | 04:09 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I don't think you really need to jack the car up... but I would for a comfort/ room issue. 2) If you call jegs they can probably give you all the info you are looking for.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
