Spindles
Old Mar 9, 2004 | 12:39 AM
nagga's Avatar
Spindles
will the spindles from my 87 TA work on my 84 Z28? just want to make sure cause i wouldnt have to spend any money that way
Old Mar 9, 2004 | 08:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes.
Old Mar 9, 2004 | 09:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
whats the year where they swap from the "old" style to the "new" ?
Old Mar 9, 2004 | 10:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I can't recall when the new style came around (maybe 90), but the two are interchangeable.
JamesC
Old Mar 10, 2004 | 06:34 PM
CaysE's Avatar
I thought they were the same all through the third generation. Are the newer ones better in some way? Lighter maybe?
Old Mar 10, 2004 | 06:50 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
It has always been my understanding that there were only 2 different spindles for the 3rd gens: One for 1LE equipped cars (to mount the PBR calipers), and the other for everything else.
Old Mar 10, 2004 | 07:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
designs, yes.
but when they started looking into modifying spindles to work with the new brake setups, they found diffrences.
Old Mar 10, 2004 | 08:49 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i seem to remember dan burk's 1le page stating that spindles from 91 and up were different in some way.
www.ws6transam.org
Old Mar 11, 2004 | 05:34 AM
JamesC's Avatar
If you own AndyZ28's 1LE CD, you'll note that there are two versions: 82-89 and 90-92. The pictures show that the latter spindles have a bit more metal (casting, I guess), so that they require a bit of grinding down in one area in order to mount the caliper carrier bracket. Because of the added material, the 90-92 versions may be a bit stronger, but in every other way the 82-89 and 90-92 versions are identical as far as I can see.
JamesC
Old Mar 11, 2004 | 06:52 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
does andy's cd show step by step instructions on cutting the spindles?
Old Mar 11, 2004 | 07:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's not much to it.... cut, drill, tap, install.
Old Mar 11, 2004 | 07:45 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
:shrug: i'm nervous as hell about cutting these spindles.
Old Mar 11, 2004 | 08:38 PM
JamesC's Avatar
Yes, Andy's CD runs you through the whole business. Like you, I was apprehensive, but the modification wasn't that big a deal.
JamesC
Old Mar 14, 2004 | 07:38 AM
CrazyHawaiian's Avatar
Car: too many ...
Talk about scared, I'm hoping to modify a set of the discontinued Belltech drop spindles and run C5 front brakes. Cant mess up!!
Old Mar 17, 2004 | 04:35 PM
Pat Hall's Avatar
The transition to the newer style spindles was during 1990. The only difference is more meat to the casting around the dust shield holes that you drill and tap to add the 1le caliper adapter brackets. I used the later style for my 1le conversion, but lots of people use the older style spindles with no adverse effects. I used a grinder with a cutoff wheel to cut down the first spindle, but I used a hacksaw on the second one, and I recommend the latter method for cutting them because a grinder cuts through so fast, if you make a mistake you're basically screwed. I also discovered that using a good hacksaw with a new blade cuts through them really easy anyways. One other thing I recommend when modifying them is to bolt the adapter bracket to the spindle using longer versions of the original dust shield bolts with large washers to attach the adapter bracket to the spindle while you drill and tap the holes. Just remove one bolt after you get the bracket lined up while you drill and tap the other hole. The bracket acts as a guide to help you drill and tap the hole straight instead of at an angle. I ruined one of the first spindles I modified because I tapped the holes at too much of an angle. Just my .02.
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
