4th gen to 3rd gen
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
4th gen to 3rd gen
hey guys i was wondering i have the chance to get swaybars from a 4th gen ws6 36mm front and 24mm rear i was doing a search and came across this
thirdgen bars go from 28, 30, 32,34, and 36. 4th gens go from 30, 32, and 34.
also i was told the rear will work fine front will not but you can use the bushings from the 4thgen front if the bars are the same size and the end links will work also.
i have a 85z28 and was wondering if this info is correct and will they fit? also are these the biggest sways bars you can get?
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 4th gen to 3rd gen
thanks
thanks
