dumb question
Car: Z28
Engine: 310
dumb question
Alright I bought some new Gabrial High Jacker air shocks, and I was starting to put them in, but I can't figure out how to get the other shocks out. I unbolted the bottom part off of the axle but I'm not sure how to disconnect the top part of the shock. Thanks.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need to get the top part of the shocks from inside the car. You need to fold back the rear seats and pull up the carpet. You will see a white foam triangle piece on each side. Take that out and you will see the top of the shock mount. Just unscrew the bolt and the shock will drop out.
Car: '90 RS
Engine: 377 LSX
Originally posted by 1986camarojoe
sounds easy enough thanks a lot.
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
haha, yea yea, I need some more room. I'm getting 265/60/15s and the dual exhaust is pretty low.
Originally posted by Matthew91-Z28
Man...its about time you bought a Chilton.
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
wow easiest thing in the world to install them man. right behind your rear seats is where they sit and it will have a little foam pad over the top of the shock. i driled a little hole by the mounting area to run the lines back into the car. drilled a small hole in the rear plastic piece to run the filler valve. looks so nasty. cant even see the lines from under the car. i was very pleased with the install
i also have a set of 02 ws6 springs that add 2 inch lift to the rear alone. i jacked the hell out of the rear and it looks awesome. running 295/50/15s back there. ill get a picture of my lift up here as soon as the snow is gone and i can pull it out of the gurage. love lifting fbodies. beats the hell outta lowering them
Car: Z28
Engine: 310
Originally posted by Stingraye
265/60/15's???? I sure hope u'r not tryin to fit that wide of a tire on a stock rim.......
Car: Z28
Engine: 310
well good luck tryin to fit that thing on those rims...
Car: 86 Camaro
Well thats exactly what I'm doing once payday comes.
NinjaNife
Aug 23, 2015 11:49 AM
