what happend here?????
Old Mar 13, 2004 | 08:34 PM
sanchez's Avatar
Car: 1990 Iroc-z G92
Transmission: 5 Speed
what did it take to do this?
It was a car that me and a friend worked on. He had been driving for months like this. And the proportioning valve was messed up and rear brakes were not working either
Old Mar 13, 2004 | 10:06 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Time and lack of use. Break rotors tend to rust apart like that.
Old Mar 13, 2004 | 10:31 PM
25THRSS's Avatar
lol, that has nothing to do with lack of use. That my friend is what happens when your brake pads wear down and you don't replace them. They dont sound good like that either.
Old Mar 13, 2004 | 10:56 PM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
You wouldn't believe how many times I saw that at my former shop. It's called maintenance people - or in this case, a lack there of.
Old Mar 14, 2004 | 02:35 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yep, thats the classic "I wondered why my breaks were noisy".
Old Mar 14, 2004 | 08:33 AM
sanchez's Avatar
whats worse is the brake pads were brandnew just a few weeks old
Old Mar 14, 2004 | 11:52 AM
MdFormula350's Avatar
WOW!
Old Mar 14, 2004 | 12:06 PM
nolanr0413's Avatar
Car: Trans am
hey dirty sanchez that looks like a major problem. Im sirprised nothing real bad happened.
Old Mar 15, 2004 | 11:29 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
the pads may have been new but how old was the rotor?
Old Mar 16, 2004 | 09:44 PM
Spdfrk1990's Avatar
Caliper must have been sticking from either the hose was bad or the pro valve maybe.
Old Mar 17, 2004 | 01:28 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
have sene this happpen, ppl dont stop driving when brakes squeal(hence squeal clips) they uusally only squeal when you are not applying brakes and go quiet whne you are applying them so ppl assume its not worn out pads and therefore they keep on driving anyways and end up wth whole entire sid eof rotor gone just like in above pic
its crazy, yep
sounds like you have no back brakes, line or hose collapsed, or bad m/c, or i dunno what else to say
good luck
Old Mar 17, 2004 | 09:56 AM
sanchez's Avatar
I don't know how old they were the appeared to be factory on an old impala. the guy drove it over like this actually he had been driving it around town like this for a while. my friend tried to drive it around the block and he could barely control the car during braking it just took of to the side of the one good brake "he refused to drive it again," my friend was working on a trany problem and found the brake problem. The owner refuse to fix the rotors and brake. so no worky from us. He totaled it a few weeks later.
Old Mar 17, 2004 | 07:46 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
well whoever put the pads in didnt inspect the rotor. no way new pads did that in a few days. now you need new pads and rotors
Old Mar 18, 2004 | 08:51 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Maybe they just put new pads on and thought those were performance slotted rotors!!
breathment
Nov 11, 2001 10:42 PM
bklucas12
Sep 28, 2001 12:35 PM
bklucas12
Sep 13, 2001 09:14 PM
nativ
Jul 28, 2001 02:08 PM
FAST RS
Dec 29, 2000 08:04 AM
