BMR trakpak
Old Mar 19, 2004 | 06:15 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
BMR trakpak
Do any of you run the BMR trakpak torque arm package? http://www.bmrfabrication.com/torque%20arm/trakpak.gif I like the idea of the seperate crossmember and the shorter TQ arm. If anyone has used it what kind of performance increase did you see? Right now I have a modified stock TQ arm. Has a 1/4" thick plate of steel welded to it. Thing is as strong as could be and has handeld low 11 second passes, but it is really heavey and ugly. I want to improve and maybe get some better suspension geometry.
Old Mar 20, 2004 | 07:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i think it looks like a pretty descent design for the stip, but being much shorter than stock, you probably wouldn't want to use it, if you use yoru car for auto-x or something that would require max. braking performance.
Old Mar 20, 2004 | 10:57 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
yep i do. and drive it everyday. not recommended for lowered cars though. there won't be enough ground clearance with the bar.
bmr trak pak installed on my car
Old Mar 21, 2004 | 02:35 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
what do you think of it? How big of an improvement did it make?
Old Mar 21, 2004 | 09:08 AM
mrr23's Avatar
Engine: 360 HSR
very nice piece. not sure if it helped much. i do have consistent 1.8 with two 1.7x 60 fts.
ZZ3Astro
Aug 13, 2019 12:57 AM
meeklay812
Oct 1, 2015 03:46 PM
luvofjah
Sep 10, 2015 10:41 AM
buckshot63
Sep 10, 2015 09:15 AM
