What size are stock 1988 Firebird Formula WS6 wheels?
Old Mar 20, 2004 | 09:35 PM
joey93turbo's Avatar
Car: 1988 Formula
Engine: 305 TBI
Transmission: 700R
I need new tires pretty bad and i'd like to know how wide I can go with the stock 1988 Firebird Formula WS6 wheels. I also need to know what diameter they are. I'm gonna give Khumo Ecsta Supra 712's a try since they're pretty cheap and i've heard good things about em. I've considered gettin new rims but since i'm extremely broke i'm thinkin about keepin the WS6 rims and spending some time removing the clear coat and polishing them.
Old Mar 20, 2004 | 10:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
stock wheels are 16x8. ive successfully ran a 255/50 bfg drag radial. had the 712s 245/45, theyre good tires longevity wise, but youre not gonna hook
Old Mar 20, 2004 | 10:38 PM
Car: 1988 Formula
Engine: 305 TBI
Transmission: 700R
What i'm lookin for is a performance/value tire with good tread wear life. any suggestions?
Old Mar 21, 2004 | 12:48 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Yeah...I suggest you search...
Besides the two suggestions already for the Kumho Ecsta 712's...what else do you want
Old Mar 21, 2004 | 01:17 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I've also heard good things about the Khumos, and they're very affordable, too. For performance AND value, it seems like a good choice.
And the stock tire size for those 16x8 rims is 245/50-16.
Old Mar 21, 2004 | 05:20 AM
Car: 1988 Formula
Engine: 305 TBI
Transmission: 700R
Can I fit a 255 on the rear?
Old Mar 21, 2004 | 08:52 AM
Engine: LS3
Transmission: 6L80E
www.tirerack.com
and you are still refusing to search...seriously...there is a LOT of info in the archives on this...
Does the information Choo-choo need to be fed to you with a spoon?
Old Mar 21, 2004 | 09:38 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
255-50 will fit at the rear, no problem!
Old Mar 21, 2004 | 12:01 PM
Car: 1988 Formula
Engine: 305 TBI
Transmission: 700R
Thanks alot guys!
Old Mar 21, 2004 | 01:10 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
BFG also makes a Radial T/A 265/50/16 that will fit in back as well. Yes, I know from experience.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
