Wheel play after new ball joints and bearings, what else could it be?
Old Mar 21, 2004 | 06:59 PM
Dean-B4C6SPD's Avatar
I had a 1/2" of play when grabbing my passenger front wheel from top and bottom. First thing, I replaced the inner/outer wheels bearings all around.. same 1/2" play.
So, I replaced the balljoints in the control arm, as well as fresh bushings. Same 1/2" of play.
So what's left?? Normally, it's wheel bearings or balljoints...what else could be wrong that would cause the 1/2" of play ?
Could it be the rotor itself that houses the bearings/races??
Thanks for any ideas!
Old Mar 21, 2004 | 08:53 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Did you put the right amount of preload on the bearings? I'd also check to see if one of the strut bolts is loose. The spindle isn't slotted but you can still wiggle it if one is really loose.
redmaroz
Apr 25, 2017 07:14 AM
zayne0
Aug 24, 2015 07:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
