LS1 Rear Disc Swap
Old Mar 29, 2004 | 06:11 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
LS1 Rear Disc Swap
Swapping 99rear disk to 87rear disk
I've searched and came up with limited info on hardline swap. Someone said to convert the 4th gen lines, Ed said the 91-92 disc will work, but i dont want to buy knew unless their all stainless. And im broke right know.
I pulled my car in on the rack at work today. It appears that the flare and size of the line is the same. my lines screwed into the caliper hose fine.
The drivers side seemed it had extra bends so i could bend and move it to were i need to. The pass. side looked to be 2" short and in the wrong spot.
So if I undid the line at the T and clips on axle tube, I could bend it were i need to.
I was wondering what others did when the did the swap
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
