Small amount of wheel spacing needed
Old Apr 1, 2004 | 09:38 AM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
Well, potentially that is. First of all, I'll ask you all if you can mount rear 16x8 IROC or GTA rims with 16mm postitive offset on the front of the car at all - would this work?? And correct me if I'm wrong, doing this with out spacers would narrow the front track of the car by about 32mm in total (16mm per side).
Is there a good, safe way to get about 10mm of spacing behind the front wheels? I don't care if I get the full 16mm nut want at least 10mm on each side if I decide to try and mount up a 16x8 rear wheel with 16mm of offset.
K
midge54
Dec 27, 2019 04:14 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
