Is the brake booster rebuildable?
And if it is, is the kit easily available? My BB is hissing pretty badly, though braking doesn't seem to be bothered too much - probably because of the Baer system up front and the LS1's out back though. I figgered if I can rebuild it, that means I can powdercoat it since it's apart anyway...
Anyone have any thoughts?
Steve
Steve
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Yeah Ive never seen a rebuild kit...Is it the booster itself leaking or the lastic barb in it that connects to the manifold...You can buy new barbs for it...
If a new one is too much $$$ find someone with a good used one... I know someone who just switched his GTA to manual brakes and has a power brake booster sitting in his garage...
END of sales pitch..
Kenwood
Kenwood
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Is the brake booster rebuildable?
Steve
Steve
Also, do check the one way valve and the grommet. Might be only be a $2 grommet.
If diaphram is hooped, I wouldn't bother. Boosters are very hard to get apart...and they have a freakin' HUGE spring inside that is extremely hard to compress.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
