sloppy brakes
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
sloppy brakes
Brakes soft, car stops, but pedal goes almost to floor. At stop in gear, pedal will go all the way to floor if you keep pushing it. Replaced front calipers, complete replacement of rear drum brake assemblies, replaced master cylinder (and bench bled), new pads, new brake hoses, bled lines - no change.
Could it be the booster? Vacuum reads 16 at idle at the hose going to booster - is that enough vacuum? I ask because my vacuum dropped with my mods - was more like 20 with stock cam & heads.
Any info appreciated.
dbrochard
Sep 19, 2015 08:13 PM
