Eibachs and tokicos illuminas are on
Old Apr 22, 2004 | 11:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I have Pro kit and Tokico illuminas on and wow is it a great improvement over my stock suspension!! My old stuff was so beat that the rear axle tube was hitting exhaust pipe and dented it slightly
The car looks and feels great. Its a little stiff but its suppose to be that way. Its an IROC!
Install was fairly straight forward but I ended up getting an adjustable panhard bar cuz the rear kicked out 1 inch. It fixed it though. Now I have little traction. Next is control arms and relocate brackets. They should help I hope.
man, this car is a money pit. I didnt think lowering would cost so much with control arms and panhard bar, a lesson learned to all planning on lowering. But best to build it from the ground up!
Old Apr 23, 2004 | 12:08 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Congrats dude. Feels good to be riding on something other than stock supension doesn't it?!?! I know mine even going to the Pro-kit and KYBs was a ton better than stock...
Old Apr 23, 2004 | 03:44 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Eibachs and tokicos illuminas are on
The rear end shifted 1"? That's pretty far. Typically after lowering, the rear will shift about 1/4". I've got a 1.5" to 2" drop with my Jamex springs and my rear end moved just about 1/4". Tom K's car was similar using Jamex springs.
You should've seen the same with your Eibachs.
Old Apr 24, 2004 | 12:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well it was about an inch. I didnt take any measurements of that type (distance inside from fender to wheel) but just wheel gap and height of car off the ground before and after install.
All I can say is that it was very noticeable to me after the car was on the ground. From the fender lip to the tire, there was a difference of one inch from the driver side to the passenger side. It was almost poking out under the lip while the other side was well under the lip. It was weird. So i got the adjustable panhard bar and it evened out the car.
Oh i forgot that the spring on front drivers side and rear spring wasnt indexed right at first so the car sat like an S-10. Maybe that affected it? But everything is squared away now.
Old Apr 25, 2004 | 10:01 PM
Kandied91z's Avatar
take note of how many miles you get before the initial annoying pogo process starts.
Old Apr 26, 2004 | 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
pogo process starts?
what's that?
Wheel hop?
I had the stuff on for a month now and no problems except loss of traction, but no wheel hop.
Old Apr 26, 2004 | 01:04 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
any pics of the car w/ the springs and shocks on?
Old Apr 26, 2004 | 09:16 PM
Kandied91z's Avatar
pogo is a generic term relating to the cars reaction as it is driven. much to the effect of a child on a pogo stick or as more commonly seen on vehicles that have had their springs cut and the shocks/struts aren't valved right to compensate.
in otherwords you'll know when it starts to "pogo" you'll feel as if you need a new suspension again. with kyb, monroe, gabriel, etc. it doesn't take much more then a few thousand miles to start and by roughly 20,000 they are completely shot. i have yet to run a tokico though so i have no idea how long they last..
Old Apr 27, 2004 | 04:15 AM
CrazyHawaiian's Avatar
Car: too many ...
Well thats just how all MacPhearson systems work. Expect a short life span. Hehehe
Old Apr 27, 2004 | 10:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Wow, that sucks.
Short life span I hope not. Those shocks are expensive. Bilstein, Koni, and Tokico shocks are the best out there. There quality should last long, heck they have lifetime guarentee.
My car only has less than 2000 miles on it since install and shocks are set stiff out back and medium up front to help with drag launches.
Sorry no pictures of it currently but I will try to get some. It looks sweet lowered but I hate lack of ground clearance lol
I had a rabbit cross in front of me and go under the middle of the car-- no wheels hit it. The airdam and/or exhaust pipes hit it. Oh, well the price you pay for the look and performance
Old Apr 27, 2004 | 10:36 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
just wait until you get to experiance the ultra embarising moment of getting your car high centered trying to get out of a driveway, at a rather expensive resraunt, with a very nice looking girl you are trying to impress, in the passanger seat, asking why you aren't pulling out into traffic.
Old Apr 27, 2004 | 12:13 PM
laiky's Avatar
he he he!
Antips16
Oct 30, 2015 06:42 PM
jbates346
Oct 21, 2015 01:50 PM
Nervous2
Oct 8, 2015 10:53 PM
gta_knight
Sep 23, 2015 04:59 PM
jbates346
Sep 22, 2015 05:22 AM
