Purpose in adjustable LCA's???
Old Apr 27, 2004 | 06:16 PM
BadBoy92Z's Avatar
Car: 1992 Camaro Z28 25th Anniversary
Engine: 5.7 L 350 w/ some mods
Transmission: 700-R4
What's your opinion??
OK, I'm lookin into gettin some Spohn LCA's and relocation brackets and just was wondering what I should get. Now is there any other reason for buying the adjustable ones besides if your car is lowered or will be lowered in the future? Because I highly doubt I will ever lower my car just because Michigan roads suck. Do I really need the Adj. ones then?? My car's not an everyday driver. I just take it out in the summer like 3-4 times a week. I wanna take it to the drag strip quite a bit this year too. Also, I noticed the adj. ones come with Spherical Rod ends which look better than the poly bushing ends. Are they?? and what's the difference?
Old Apr 27, 2004 | 07:32 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Purpose in adjustable LCA's???
The adjustable LCA's let you reposition the rear end if desired. For your intended use, they probably aren't necessary.
The rod ends are preferred for improved cornering if you like to take corners. The downside is the rod ends have somewhat of a short lifespan and need to be replaced periodically. The poly bushings last a long time and only require an occasional shot of grease.
For drag racing, the non-adjustable poly bushed LCA's are ideal.
Old Apr 28, 2004 | 08:43 AM
CaysE's Avatar
Do a search my man
https://www.thirdgen.org/techbb2/sho...hreadid=234074
Old Apr 28, 2004 | 09:45 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just buy the standard non-adjustable LCA's for your car, they are a good impovement over the U-shaped stock ones. Just leave the adjustable parts to the guys who like adjusting things.
Old May 2, 2004 | 06:36 PM
BadBoy92Z's Avatar
ok , I think I'll just get the non-adj. LCA's, but should I still get the relocation brackets then?
Old May 4, 2004 | 04:07 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Yes. It will improve the position of your instant center, thus improving traction greatly. Lots of people say you dont need them, but they dont think about or understand instant center.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
