Best complete polyurethane bushing kit
Subscribe
Apr 29, 2004 | 01:17 PM
What is the best complete polyurethane bushing kit for a camaro? I want it to have motor mounts, sway bar end links, front and rear sway bar mounts, transmission mount, and torque arm mount.
Reply 0
Apr 29, 2004 | 02:12 PM
My vote is for Prothane.
Reply 0
Apr 29, 2004 | 05:33 PM
If you want the most complete, you may want to buy a Hyperflex kit from ES and then just add the parts it doesn't come with. I don't think it will come with the motor mounts. Also, if you plan on getting aftermarket LCAs and panhard rod, these will have poly already installed in them so you'll have those left over from the kit. I just pieced mine together so I'd have what I needed, and went with all ES parts. Link is in sig.
Ed
Reply 0
Apr 30, 2004 | 08:07 AM
As far as I knew, the Hyperflex kit doesn't come with nearly as much as the Prothane Total kit.
Prothane (from spohn.net):
Rear Lower Control Arm Bushings
Panhard Bar Bushings
Ball Joint Boots
Torque Arm Bushing
Tie Rod Boots
Front Sway Bar End Links
Front Sway Bar Bushings
Rear Sway Bar End Links
Rear Sway Bar Bushings
Transmission Mount
Front Control Arm Bushings
ES (from energysuspension.com):
Front control arm bushings
Rear control arm bushings
Front strut bushings
Rear shock bushings
Front end link set
Panhard bar bushings
Ball joints
Tie rod end boots
Reply 0
Subscribe
