Tire size?
Old May 1, 2004 | 04:55 PM
snipcod's Avatar
Car: 1984 z28 Camaro
Tire size?
What would be the best size tire to have on a 84 camaro. The most commun size I found is a 245/45/17. Just woundering if I could fit wider on the rear. And have no problems.
Old May 2, 2004 | 06:33 PM
Bandit5's Avatar
What wheels do you have, and what size tire is on it now?
Old May 2, 2004 | 11:30 PM
snipcod's Avatar
Well as of now there stock. But I was just looking around. I was told that I sould try to put some thing wider then 245. Dont have any rims as of yet. Just wanted to know if you can fit wider with out any problems.
Old May 3, 2004 | 08:52 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
with the right offset (or adapters) you can go 275/40-18,, they fit.. You can check the article on CHEVY magazine, several months ago thay explained a complete supension upgrade to a 3rd Gen camaro.. I got 245/45-17 on mine Camaro but I wish I had wider at the rear... Check my home page for pictures..
Old May 3, 2004 | 08:01 PM
Bandit5's Avatar
Stock wheels came in 15" and 16". The tires you two listed are for 17" and 18" wheels.
Now, with 245, those are standard for 16" wheels: 245/50/R16. The widest that will fit and still be safe would be 285/##/R16. However, I wouldn't go any higher than 275. Good luck finding anything in that size though, you can find a few in 255 and more in 265.
Personally, if you use good tires, you don't ahve to go so wide. Put on some BF Goodrich G-force T/A KDW 245/50/R16 and you will see a difference.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
