Brakes?
Old May 6, 2004 | 10:10 AM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Brakes?
I recently replaced my brakes over the weekend. Front brakes only.
After I did so, when I stop now I get a wobble effect, side to side, left to right.
I know what a car does when the rotors haven't been turned.
When you brake, you get like a skip/jerking effect front to back.
I didn't turn my rotors, do you think this is the problem?
I also read some where on this section, that if your rotors are too thin, you will experience left to right shaking when braking.
I know that the driver side brake is loose, I can hear it sometimes.
You know how you have to bend those tabs back to to make the brake fit tight on the caliper? I think I didn't bend it back enough, because I think I can hear/feel the pad moving when driving.
Thanks,
Old May 6, 2004 | 11:05 AM
ede's Avatar
ede
i think rotors might be the problem. cheap as they are it's often better to replace them than to have them turned
Old May 6, 2004 | 03:10 PM
fyrechikyn's Avatar
i had the "hop when brakes applied" syndrome and couldnt figure it out i checked the runout of my rotors and it was only .001 off so i turned them and problem solved amazing how .001 of an inch affects your brakes
Old May 6, 2004 | 03:21 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Yeah, I think I'm just going to remove the brakes get the rotors turned and fix the pads.
Then see what happens.
Thanks,
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
