F41 camaro
Car: 1992 camaro RS
Engine: 305 TBI
Transmission: T700-R4
F41 camaro
i just descovered that my camaro has the RPO code F41, and thats the suspension system stuff.
Whats that mean for me if compaired to a non-f41 ro whatever?
and does teh value go up?
Car: 2002 Z28
firmer ride, better handling. Probably has bigger sway bars and higher rate springs, but im sure if you have some miles on your car most of the suspension parts are gonna be worn out or on their way out. And i doubt it will really increase the value of your car.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
No value increase...Specifically on the '91 and '92 cars, this package included the 16" alloy wheels and 34mm hollow front and 21mm rear sway bars.
Ed
Ed
Car: 1992 camaro RS
Engine: 305 TBI
well i just had the suspension replaced with teh original matching suspension, thats when the suspension people pointed out that it was different then normal camaros like it. just wondering.
And yes once it was changed i noticed a hella difference in the cars handling.
Thanks.
Thanks.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
My Camaro is a factory F41 car. 32mm front sway bar with an 18mm rear bar, Z28 springs, and the G-vin sterring box (the good one). My car also came with factory rear disc brakes - which is not part of the F41 package, but cannot be ordered without it (kinda like a pre-1LE without the good parts from later years). Essentially it is a Z28 suspension with either 14" or 15" wheels (depending on the year - my car, an '84 had 14" rubber).
84z96L31vortec
Aug 20, 2017 12:16 AM
