Rear Coil Spring Part #
Old May 13, 2004 | 02:04 PM
kaupca's Avatar
Car: 92 Camaro RS
I read a lot of people suggesting using a Moog 5665 spring on the rear of a 1992 camaro. All of the parts books list a CC635 variable rate spring. What is the 5665 intended for? What is the difference between the two springs? Thanks
Old May 13, 2004 | 05:47 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
What parts books are you referring to? I believe that one set of moogs are a linear rate spring and the other are the "cargo springs" that is a progressive spring that increases the rear ride height.
Old May 17, 2004 | 07:25 AM
kaupca's Avatar
Car: 92 Camaro RS
Coil spring part number
I found the part number on the web site for Advance Auto Parts, Autozone, O'reilly's and Federal Mogul (Moog).
Old May 19, 2004 | 02:05 PM
Pat Hall's Avatar
I think the ones I got were the progressive or "cargo" type springs. I think they were listed as variable rate or "hef-t coil" type. I like the replacement springs better than the NNL code Iroc springs I had in the rear. Then moog springs are actually stiffer and have a better ride height too.
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
1nastygta
Aug 8, 2015 07:38 PM
