What Proportioning valve to use with rear drum to disc swap?
Old May 14, 2004 | 11:57 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
What proportioning valve did you guys use when swapping from rear drums to 9 Bolt w/ discs? I am most likely going for a Wilwood Prop. valve, and am also gettting Goodridge SS braided brake lines as well. But I just wanted to know what prop. valve you guys used, just curious?
Old May 15, 2004 | 12:08 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
you can get the wilwood **** type from both Jegs and Summit for like 30 or 40 bucks. I believe that is the most popular one used. I will be installing one along with my rear here soon.
john
Old May 15, 2004 | 01:05 AM
Car: 1989 RS Camaro
Do you know if it comes all ready to be installed, or would i have to order like fitment stuff as well?
Old May 15, 2004 | 07:05 AM
ede's Avatar
ede
the flat sided aluminum machined piece from gm will work. take a look you may already have it.
Old May 15, 2004 | 07:45 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
P/N 14089496 for the 1LE/PBR rear discs.
Ed
Old May 15, 2004 | 01:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
ive got a wilwood one i dont need, 40 bucks to your door, brand new
jaridjohn
Jul 8, 2024 03:49 PM
hectre13
Dec 11, 2023 08:14 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta90
Sep 15, 2015 04:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
