SFC for autocross
Old May 15, 2004 | 06:16 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
SFC for autocross
Hey, I was gonna order Alstons.. but then heard that they're
best for drag racing.
Maybe that wasnt entirely true, I wouldnt know ..
I want a set that are true bolt ons (will be welded) ..
No adding pieces of metal.. or needing extra extentions ..
Tnx
Old May 15, 2004 | 06:24 PM
Rembrandt's Avatar
Here you go mang:
http://www.swracecars.com/camaro_boltOn.asp
True bolt on, lateral AND longitudinal bracing, it looks like a pretty serious piece, seeing as how it is the only connector that goes all the way across the car.
Be our hero and tell us what it's like!
Old May 15, 2004 | 10:09 PM
Rembrandt's Avatar
In case you didn't know S&W is the same company that makes the roll cages that Spohn sells, so they have quite a bit of experience and resources to know how to make excellent bracing.
The whole Alstons for drag, Spohns for handling really is just theoretical. Yes, it does make sense that compared to the width of the car, the Alstons don't go out wide enough to counteract a torsion force as well as Spohns might. Also it seems that for weight transfer and bending flex (lengthwise), the Alstons have a more direct load path than Spohns.
Given that last thread about the Alston's poor fit, I don't consider them as highly as I used to. Everyone just assumes things slip on but you have to remember that humans welded these things.
And since Spohns don't bolt on, the S&W seems better than some of the misc cookie-cutter bolt-on subframes.
Old May 16, 2004 | 09:03 AM
Spectre's Avatar
Engine: 3.0L/183
These look real nice ...
Ill see if I can find them here.. (and for what price lol)
Tnx
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
luvofjah
Sep 10, 2015 10:41 AM
