rear spring and shock installation Q's
Old May 23, 2004 | 09:35 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
I finally got the front done. Complete pain in the butt that was. Anyways, now its time to do the rear. I was just wondering if the springs will be easier to remove and put in. Also, will I need to use the spring comressor for the rear springs? And finally, does it take a while for the springs to settle? My front doesn't really look any lower than before. Thanks
Old May 23, 2004 | 10:10 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
no, you dont need a compressor for the back. just support the rear with a jack, unbolt the shocks from the inside, which is kinda a pita, then lower the rear, and the springs will just fall out
it will take like a week of driving for the springs to settle
Old May 24, 2004 | 01:48 AM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Good, thats what I wanted to hear. Using that compressor was like playing with a loaded gun. Glad the hard part is over with.
Old May 28, 2004 | 01:27 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you dont have to unbolt them from inside, just undo the lower nut on the rear end. the springs come out very easilywhen the shock bolt is taken off. LMK if i can help.....
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
