What year ebrake cable???
Old May 31, 2004 | 01:12 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I was checking some stuff out online and from what I can tell, gm-parts-for-less.com shows that the ebrake cable is the same for all 4 wheel disc from 84-89, and 90-92 is another model. BUt this doesn;t make sense since 89 already had the PBR calipers... What gives? Should I just play it safe and order the 90-92 models, since they do use PBR's as well>? Thanks guys
Will
Old May 31, 2004 | 01:19 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Yes. '89 1/2 is the cutoff line from Moraine to PBR They were half and half in 1989. If you have PBR's then go the later.
Old May 31, 2004 | 08:38 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What he said. If you have or are switching to PBRs, go with the cable spec'd for '90-92.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
