sway bar diameter?
Old Jun 5, 2004 | 07:13 PM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
sway bar diameter?
my car needs a front end rebuild and i was considering this kit:
http://www.hawksthirdgenparts.com/inc/pdetail?v=1&pid=9289
but it asks for the sway bar diameter. what would this be for my car? i cannot measure it my self as the car will not arrive till the end of the month as i have just bought it from the USA.
Cheers.
Old Jun 8, 2004 | 02:36 PM
warlord's Avatar
Any ideas?
Old Jun 8, 2004 | 02:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
their is a chart around on this site that list years, options, etc. Seach swaybar, it was a while back though.
Also, after 15+ years, it could have easly been changed. We could tell you, but it would be a pigon shot.
copy/paste from another post...............
FYI, RPO codes are as follows from the decoder:
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
FE1 : SUSPENSION SYSTEM, S0FT RIDE
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
FE3 : SUSPENSION SYSTEM, SPORT
Unable to locate code ZK3 in our database!
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
ZK3 is the export model so if you have one, you know who you are. Part numbers follow the descriptions.
91 F41 FRONT (34 MM) 14094339
91 F41 REAR (21 MM) 10021221
(REAR POSSIBLY FE2 ALSO)
91 FE2 FRONT (36 MM) 14094344
91 FE2 REAR (24 MM) 10035033
90 (NO CODE GIVEN) FRONT (36 MM) 14094344
90 (NO CODE GIVEN) FRONT (34 MM) 14094339
90-91 FE1 FRONT (30 MM) 14047916
90 (NO CODE GIVEN) REAR (24 MM) 10035033
89 FE2 FRONT (36 MM) 14094344
89-91 FE1 REAR (18 MM) 10021220
87-89 FE2,F41 FRONT (34 MM) 14094339
88-90 FE2,F41 REAR (21 MM) 10021221
87-89 EXCEPT FE2,F41 FRONT (30 MM) 14047916
87-88 EXCEPT FE2,F41 REAR (18 MM) 10021220
86 (NO CODE GIVEN) FRONT (27 MM) 14019268
86-87 EXCEPT ZK3/Z28 FRONT (30 MM) 14047916
86 ZK3/Z28 FRONT (34 MM) 14094339
86 EXCEPT ZK3/Z28 REAR (18 MM) 10021220
85 FE2 FRONT (34 MM) 14073013
85-87 FE2 REAR (24 MM) 10035033
85-86 ZK3 REAR (21 MM) 10021221
85-86 Z28 (EXCEPT FE2) REAR (21 MM) 10021221
84-85 ZK3/Z28 FRONT (32 MM) 14047917
84-85 EXCEPT F41, ZK3/Z28 FRONT (27 MM) 14019268
82-83 (EXCEPT Z28,F41) FRONT (27 MM) 14019268
82-83 Z28 FRONT (32 MM) 14047917
82-85 F41 FRONT (30 MM) 14047916
82-84 Z28 REAR (21 MM) 10021221
82-85 F41 REAR (18 MM) 10021220
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
