WS6Ray
close
- Join DateJun 2004
- LocationHac. Hts. CA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1989 Formula 305 TBI WS6 & 1967 Firebird Turbo 462
- Engine305 TBI,Headers,3 inch Race Magnum, CHIP,EDL-2101 Intake,MSD 6AL,LT1 CAM
- Transmission700R4 w/ 2 coolers, shift kit
- Liked:0 Times in 0 Posts
Can I squeeze 275/285/295's on my stock 16x8 WS6 rims?
Probably wouldn't be a good idea.. I think 255 is the reasonable limit..
WS6Ray
close
- Join DateJun 2004
Yeah, maybe a 265 with beadlocks and inner tubes!!!!!!!!!!!
I think the problem you get when you go with a wide tire like that, is nobody seems to make a low profile version in 16". They all seem to be like 60 series or you might be able to get a set of racing slicks.
My dad has 295s on a GTA wheel. Yearone said they would fit and for a year they haven't been a problem.
91banditt2
close
- Join DateDec 2000
- LocationCincinnati,Ohio
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1991 BandittII Firebird
- Engine5.7 HSR
- Transmission700R4
- Axle/Gears3.27 9 bolt
- Liked:151 Times in 111 Posts
Quote:
is that a 50 or 60 series?got pix?Originally posted by TransAm12sec
91banditt2
close
- Join DateDec 2000
- Engine5.7 HSR
- Transmission700R4
91banditt2
close
- Join DateDec 2000
- Engine5.7 HSR
- Transmission700R4
/50. I don't have any closeups of the tire on the wheel.
I have 17x8 inch rims and am currently using 275/40r17's nitto drag radials on em. 255's for the front.
here is a pic of my car when i had 16x8 ls1 camaro wheels with 295/50/16 they fit with a little "massaging" of the inner fenders.
i run a kumho truck tire out back. its a 255/55/16. it looks sweet, and fills the gap. you will never go back to a 245/50 again. the tire is a lil heavy, but with 24psi in them, they hook pretty good, and the tires last forever (even doing 20+ burnouts on them)
jegs.com has the cheapest price on them, seeing they dont kill you with a fat shipping rate on rubber.
good luck.
good luck.
I've got 245-50-16's on my WS-6 16x8's. If I wanted to go wider, I'd have to find 2 more offset's like the front. As it is now, I only have about an inch of room left between the side wall and the inner fender well. If you go any taller, you'll just throw the speedo off and kill some of your bottom end take off power!
The form. WS-6 came with 245-50-16 gatorbacks from the factory.
the 255/55 is only 27.0 it may throw the speedo off 1-1.5mph. a 245/50 is only 25.65 (most brands)
