Rear end squeak!!!
Old Jun 12, 2004 | 06:54 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Rear end squeak!!!
Hey guys I was wondering if you could tell me what else could be causing the squeaking when I go over rough drive. I just had my shocks replaced. Maybe they put a bad shock on??? Also when I make sharp turns,my front tires make that tire squeeling sound if i'm turning left or right. What could that be???
Thanks for any info!
Knight75
Old Jun 12, 2004 | 08:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Worn bushings in the rear (LCA/Panhard rod) are most likely the culprit.
Old Jun 13, 2004 | 12:20 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Power steering pump. Check your fluid level. Is it low? Fill it.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
