Right wheel pointing out
Old Jun 14, 2004 | 12:28 PM
KingChris's Avatar
Car: 89 Trans Am
Engine: 305 TBI
My front right wheel is pointing out and the tire is worn out while the other 3 arent. Do i just need a wheel alignment or is there something else wrong that i can do to straighten it out? Thanks.
Old Jun 14, 2004 | 12:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like you need a wheel alignment and new tires.
Old Jun 14, 2004 | 06:38 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hopefully all you need is an alignment. Usually alignments dont go out that bad unless something is bent or was left loose at the last alignment.
Old Jun 14, 2004 | 08:46 PM
KingChris's Avatar
Car: 89 Trans Am
Engine: 305 TBI
Well the wheel is noticeably pointing out and is noticeably more worn out then the others. Is there anthing i can visually inspect myself to tell if something is out of adjustment or needs replacement? I would like to fix the problem as best i could until i have the money to buy a new used tire and get it professionally aligned. Thanks.
Old Jun 14, 2004 | 10:59 PM
CaysE's Avatar
Yes, just get under the car and look at all the steering linkages. It's basically a bunch of metal rods with ball joints at the ends linking them together. It sounds like something is messed up if you can clearly see one tire pointing in the wrong direction.
Old Jun 15, 2004 | 07:16 PM
dankhound's Avatar
Car: 91 RS
If some thing is broken you may still be able to adjust the tie rod so that the wheel is pointing somewhat straight.
Old Jun 16, 2004 | 03:52 PM
KingChris's Avatar
Car: 89 Trans Am
Engine: 305 TBI
OK thanks guys ill take a look at it.
Jorlain
Aug 24, 2022 05:11 PM
Scamo-2.8
May 20, 2016 07:01 PM
Ducati900ss
Sep 2, 2015 09:05 AM
someone972
Aug 30, 2015 12:52 AM
kah992
Aug 19, 2015 02:55 PM
